Re: 79 Sterndrive Trim Ram Question
I didn't take pictures, sorry, and I already put it back together. You were right Howard, it was a non issue. I did find problems when resealing the cylinders (blown seal), but it's still crooked in the up position, and trimming the engine doesn't make any noticeable difference while running the boat out on the water. After spending a total of 250 (motor and seals) on the engine trim, I realize I won't be using it, because it doesn't do anything.
I'm happy to have it running for the summer though. I'm going to tear the inside out and renew it next spring (stringers and all). I had to remove some rotten wood around the transom seal and patch with new wood for this summer. Plus the rear couple inches on the stringers were rotten. I figured the outdrive mounts might have problems. so I put some 3/8" thick, 3' long plates along top of the stringers for this summer. I tapped the engine and outdrive mounts to 1/2" NC and screwed the plate to the stringers with a bunch of 1/2" lag bolts.
