80 175 mercury
CU2NITE
Re: 80 175 mercury
All outboards are generally the same when winterizing. Put stabilizer in fuel(run on ears until stabilizer gets in carbs), fog the carberators(I also shoot a little in each cylinder after the carbs are treated), change lower unit oil, pull prop to make sure no fishing line is on the shaft, charge batteries good(or pull them) and I recomend storeing the boat with the motor in a down position(it lets all the water run out). Good luck.<br />CU<br /><br />------------------<br />RUNNING THE MOTOR WHILE LISTENING TO THE HORN WILL MAKE YOU MORN!!
