80 2.5 140 HP MERCRUISER
DOUBOY80
JUST BOUGHT THIS BOAT AND THE STARTER IS LOCKED UP DOES THIS MOTOR ROTATE IN CCW ROTATION OR IN CW ROTATION AT THE CRANKSHAFT PULLEY. ALSO DOES ANYONE KNOW HOW YOU CAN CHANGE OVER TO ELECTRONIC IGNITION OR AM I JUST GOING TO HAVE TO LEARN POINTS.
Walt T
Re: 80 2.5 140 HP MERCRUISER
First be sure it isnt the engine that's locked up. The engine should be standard rotation if it is a single engine set up. (CW)<br />Electronic conversion kits are easily available from any marine dealer for around 100 bucks.
johnkc
all mercruiser STERNDRIVE engines with a #1,R,MR or Alpha drive turn Counter Clock Wise viewed from the flywheel end.which is also called standard rotation.
LubeDude
Pertonix is very easy to install, and maintenance free, about $85.00. Just go to your local auto parts store with your information and they will fix you up
Trent
Sorry Johnkc.. Not all Mercrusiers are CCW. Their are a couple of oddballs out their.
Trent
DOUBOY80... The 2.5 is not a 140HP its a 120hp.
DOUBOY80
ok if the 2.5 is a 120 then what size motor is the 140?
Fishermark
I know the 3.0 liter Mercruiser in my Dad's Sportcraft, (I'm working on it right now! :mad: ) is 140 HP.
Walt T
its CW looking at the crank from the front. CCW looking at the flywheel is correct but you cant really see that when the engine is running.
well i know this isn't a 3.0 v6 it is an inline 4
I-4 2.5l = 153cid = 120hp.....<br />I-4 3.0l = 181cid = 140hp.....<br />V-6 4.3l = 262cid = 175hp/205hp.....<br />V-8 5.0l = 305cid = 200hp/230hp.....<br />V-8 5.7l = 350cid = 260hp(other hp ratings are also ava.)<br /><br />BTW, Nobody has mentioned this so I will,<br />Loose the Cap-Lock........<br />I Don't like to be YELLED At......<br />And, It's Harder to Read....... :mad:
WillyBWright
Hard to read?<br /><br />Did you konw taht if you scrbamle the letetrs btewen the fisrt and lsat leettrs of wrods wihtin a stenence taht you wlil be albe to raed jsut aobut as fsat as nromlal by the tmie you fiinsh rdeandig the frist prargpah? It's a phnenomea stdueid at Cmarbdige Uvernistiy. You look at wrdos as a wolhe and yuor biran ptus the lteters in the crorcet oderr.<br /><br />Did it work? Were you able to read that? It worked for me. If you try to read it out loud, it doesn't work as well. It works best if you try to read it as fast as possible.<br /><br />Waht wree we tlkanig aoubt aynohw?
Yep, It Worked.....<br />I Still say it's Harder to read ALL CAPS THOUGH....... :D <br /><br />And, It's considered YELLING !!!!!!! ;)
