80 Evin 25 wont shut off
brim_buster
In an earlier thread I had issue with no spark. Got that problem fixed with charge coil. Now the engine fires right up, mind you I have the kill switch black and yellow wire disconnected, and when I turn the key off the engine still runs. Brand new key switch that was working fine. Any ideas what I did wrong?
Joe Reeves
The black/yellow wire is the kill circuit. It must be connected to the raised "M" terminal of the ignition switch in order for the ignition switch to shut the engine down.
brim_buster
I just disconnected it for testing for spark and does it connect to the coil which I think this one was when I disconnected it. Its connected in the ignition switch still. This was a tiller converted so it has both a starter and kill switch button on the motor
brim_buster
Got everything straight..Thanks for all the help Gentlemen;););):joyous::joyous:
