80s MR 140
brucec
Removed the engine to replace transom mount. Front engine mount pin/bolt is bent, Is it supposed to be to allow for minor alignment or did manufacturer bend it to make it fit?
Thanks in advance
Bt Doctur
brucec
how does one adjust alignment side to side? Just the loosening of the lag bolts?
Bt Doctur
If the lateral alignment is off, remove the lags A , loosen the rear bolts, shift motor into alignment, Tighten rear bolts, re-check alignment. Re-drill new holes for the lags
