81 Evinrude 140 HP overheating - W/New thermosat
cdeitzel
Hello all,<br /><br />I just purchased a Grady White with 81 Evinrude 140 OB on her, and she is overheating. The thermostat was replaced, and now the port side runs cool, but starboard is overheating. Mechanic that did the work claims "I can take the thermostat out, and it will run fine without it, as it is an older motor - you can't get away with that on a newer model"<br /><br />Is this accurate, or am I getting fed a line...I am new to boating, but sounds to me that they put the thermostat there for a reason!<br /><br />Will I damage the motor if I run it without the thermostat even if it runs cool?
moderator1
Re: 81 Evinrude 140 HP overheating - W/New thermosat
Moving to Johnson and Evinrude Troubles/Questions.
D
DJ
Guest
You are being fed a line.<br /><br />Along with stats, one should replace the bypass valves and grommets. All are in the same place.<br /><br />It might not be a bad idea to pull the heads and make sure the water diverers are still there and in the right place.
P.V.
Really, the engine should have a thermostat to run corectly! Taking out the thermostat is at best, a band-aid to a different problem!! If you are confident that the water-pump is operating correctly, it's probably the pressure relief valves that are sticking. You have two choises to overcome this problem. I've discribed it way back but I'll do it again. The pressure valves (2) are located just next to the two thermostats, just at the aft edge of the powerhead, in a not so friendly location. Often the valves get stuck in their rubber seats and prevent water from reaching the other side where the sensor side of the thermostat resides. Sometimes salt contributes to this sticking of the valves (and removale and cleaning is the only solution) and also slight modification to the valve so as to let some of that captured water seep to the other side of the valve may be needed if you choose to go "inside" the thermo covers! . Now, here is a quick fix that you may care to try, or not!!! This problem manifests it's self often if you just start up the engine and let it idle a while versus taking off and getting high rpms and hense more water pressure. The symptom is one head is "cool" while the other gets real hot! Big time, if you don't monitor the horn, the smell of melting wires, etc..... So, remember this, I will assume that the "tell-tail" is strong and one head was in-fact cooler than the other! So, we'll assume the water pump is in fairly good shape! (BTW, the only correct way to determine this fact is if you visually inspect the pump!!!) Anyway, This "trick" will probably solve your prob;em without actually taking a wrench and going into the motor. When you first start up this engine the next time, either on the flusher or in the water, flip the carb linkage roller (you can use the warm-up lever if you like) and give this engine some good high revs. Once maybe twice, as it sits there at your driveway or at the dock. We're talking some serious rpms!! The increased water-pressure(due to higher tpms) very well may "un-seat" the offending pressure valve so that it may/will work correctly from now on! (and hopefully, not stick again!).Moniter the cylinder head temp and if it still gets "frigg'n hot" to the touch, well, stop on the third try and again, get out the wrenches and have fun!! Now, before someone goes ballastic about "high rev'n" a fairly cold engine, which we all agree on is not really the "right" thing to normally do, Yes, we understand.. But we are trying to accompolish un-seating the pressure valves and one or two short "raps" will do no harm! If you don't like this "idea", then don't do it and ... get out your wrenches!! This problem manifestgs it-self more often in the spring after a few months of inactivity (the valves are held shut by springs) and one or two uses and fluctuations often help them becoming unstuck! Or, again, perhaps salt/minerala may have them suckers real stuck!! Good luck!! BTW, I've done this "trick" many times and have never had any adverse effects ie. rods busting through the side of the block, etc... but again, if it doesn't break free after the third "rap", go to Plan B.
cdeitzel
Thanks to all that replied, I am going to try P.V.'s advise first, as it does seem to make sense with 6this particular mototr. The person I bought boat from assured me several times he had no problems with overheating last year...<br /><br />I really do appreciate the advice, and will let you know how I make out.<br /><br />THANKS
Dhadley
I would look at the deflectors like DJ mentioned.
cdeitzel
Well - finally got it all cleared up - got her out on the water, and it's no longer overheating!!! Thanks to all that replied - I have a new challenge: <br /><br />First, the boat is a 1970 Grady White Atlantic Weekender, Fiberglass hull, weighing in at 1560 lbs. from manufacturor. When opening her up, I noticed two things happenening:<br /><br />1) Boat began to tilt severely to port NOT pulling to left, but LEANING to left...<br /><br />2) I had only reached a top speed of about 24 MPH (of course, the severe "tilting" I'm sure played a large part in performance, and is probably connected).<br /><br />Any help would be appreciated!!
