81 Evinrude outboard. Water circulation issue
Wedge01
I purchased a 1981 25 HP outboard. The guy swapped out a long shaft and put on a short shaft. It seemed to run fine initially. It would pee properly in the tank, and when sitting at the dock, but had issues restarting after running a while. We thought it might be an electrical issue. After cooling down, it would usually start up again. Three times needing a tow back to the dock.
When I took it back to him, he said it was overheated and my fault. While testing it I had run it in a can of about 18 inches of water. It was deep enough for the water intake to be submerged, but wouldn't pee. When I put it into a deeper barrel, the same depth as the functional waterline, it would pee. I noticed there is an additional hole higher up that lies about 1 1/2 inches below the waterline when on the transom. If water went in there, it would pee, if not...no circulation.
I assume this is an added overflow or drain hole, but can not find pictures. I need to prove this guy sold me a motor that was not circulating properly. I believe that when running on th lake, this hole was not getting water due to hull displacement.
Fed
Not deep enough, the water pump which is at the very top of the gearcase needs to be fully submerged so the seller was probably correct.
Wedge01
.The guy did the mount onto the boat. Its a shallow 15 inch transom so he suggested turning it into a short shaft. Took it to the lake three times. All three times it would not re-start. The motor was obviously overheating before I ran any tests in a tub. Can anybody show me on a picture of where the water level needs to be?
What is the name/function of that hole that is on the forward side of the shaft. its about 6 inches below the bolt line of the engine head.
Wedge01
Wedge01
This isn't the same motor, but similar, and my bucket was even deeper than this. Cavitation plate was always about 4-6 inches underwater. The hole I'm talking about is on the exhaust section.
Water in the bucket shown above MUST be 8" higher.----A simple rule.
Wedge01
Still doesn't address the fact that the motor was not circulating water when running out on the lake, but circulating when sitting at the dock. I can't seem to find any pictures with the hole in the exhaust housing that seemed to be the only place where the water was actually entering in from. Looks like this is not typical on other outboards.
hardwater fisherman
The pump housing is sealed and gets water through the intakes and nowhere else.. Any holes you see are probably drain holes. If you ran it long enough without water you probably ruined the impeller. And maybe the motor also.
I belive the main water intake is the screen in the snout behind the propeller.
oldboat1
sounds like the intake below the plate might be clogged -- screen in that nose protruding in front of the prop. That is the primary intake when the boat is underway. There is also an intake just above the plate on one side of the housing, and that intake would draw some water at idle or when in reverse.
Wedge01-----I suggest you learn more about the way your motor works before operating it again.-----Talk to your local repair agent and ask how your motor works.-----Or learn through an empty wallet as has been done many , many times.
oldboat1
http://ww2.iboats.com/Gearcase/dm/cart_id.914006580--session_id.829972256--view_id.1548449
Might find this diagram useful to identify the intake screen down by the prop. Also note that the location of the impeller is at the joint between the exhaust leg and the gearcase. The water level needs to be substantially above that point.
If the screen is blocked, don't try to remove it unless it needs to be replaced -- particularly if this is a salt water motor. Use a small brad to clear blockages. Modern "muffs" don't work in flushing this motor, so you are on the right track in using a barrel. I recommend a plastic trash can, with the water level about half way up the leg of the motor. Run at idle or fast idle only.
Vic.S
The picture attached shows the joint where the water pump is located. Water must cover it by several inches
I dont know about any hole on the forward side of the shaft 6" below the power head but the exhaust back pressure port is at about that height on the aft face of the exhaust housing. Also indicated in the picture.
A decent picture of your own engine would have made this explanation a lot easier to compile
thatone123
Banned
I know that the 15's will run in hardly any water when on shallow water drive? Other makes and horsepowers also. See "Who needs a mud buddie" on UTUBE
F_R
wedge, if you are talking about the hole or holes in the forward side if the exhaust housing, down near the lower mount bracket, those are drain holes for the drive shaft isolation tube. They are not water intake holes. Water will flow OUT of them when the motor is running. The water coming out is water that has escaped through the hole in the water pump housing where the drive shaft passes through. If it were not drained off, it would rise up in the drive shaft isolation tube and eventually cause catastrophic damage to the powerhead.
I wonder if the guy that did the 15" conversion installed the short isolation tube spacer between the pump and exhaust housing? Just wondering out loud.
thatone123
Banned
I know that many times when this type of problem occurs the head is gunked up with something. Salt deposits are common but some types of fresh/brackish water are not good either, but way more rare. I'm fooling with a 8hp Suzuki right now that I have had to pull the head cover and water jacket. Put in new water pump impeller and cleaned out all passages in lower unit. Still have the found the culprit and twisted 4 bolt heads off the water pump jacket indicating how fouled that head area is with salt.
