81 gamefisher help
SkiTTleD
Hello, I've used the forums many many times at this site and has been very helpful through the years, not sure if this is in the right spot but i know this motor has been referred as a force, if its not please put me in the right spot. I have a 81 sears/eska gamefisher 7.5hp model number 217-585940. First question is what is the ports on the side of the powered? At sears site in the diagram they are called "adapter cover". Also, as for the cylinder head i want to check to make sure it isn't warped and would like to resurface it. How would i go about checking it? Because it isn't flat like most cylintder heads, it has a dome at goes into the cylinder.b
jerryjerry05
Re: 81 gamefisher help
Profile,location. You might be close to someone who can help?
Pictures will really help. Not sure of the covers your talking about(port/starb.)
As for the warp,what are you trying to check? To check the block for warp you'll probably need to remove the pistons. A piece of glass is about as flat and even as your gonna get.Unless you wanna buy a Last Say Block.It's a granit block finshed to perfectly flat.Couple hundred $ last I knew.
To check the edges a cheap plastic ruler works.
ezmobee
If it's an Eska, then it's not a Force (plus Chrysler didn't become Force until the late 80's anyway). Eska's were air cooled.
SkiTTleD
Profile,location. You might be close to someone who can help?]
I have updated my profile with my location.
They are on both port and starb. sides
I have already checked the block for warpage, that is not my concern, my concern is the CYLINDER HEAD.
I have uploaded pictures for you, in the first 2 pics, are the "adapter covers" and i the last 2 pics are of the cylinder head with the "dome" protruding which goes into the cylinder. i want to know the best way to check for warpage on the head, and if any would like to get it trued. I do know of a couple machine shops around my area but they are for car and truck engines, (I used to build SBC`s and ive built a couple blaster engines, ive been a mechanic for the past 12 years) so i know what im doing in that aspect just never dealt with a cylinder head with a "protruding dome" lol. nor do i know if they deal with small outboard engines, figured i would ask people that have more experience in the outboard scene.20130328_152133.jpg20130328_152143.jpg20130328_152201.jpg20130328_152209(1).jpg
SkiTTleD
sorry, like i said not sure if this was the right spot, if possible please move me to the right spot, Thank You.. and yes it is air cooled.
ezmobee
You're in the right spot! Cuz that's not a Force.
M
mrcrabs
Guest
Get a head gasket slather some indianhead on it and bolt her down....all Eska heads are warped....lol...I know cause I R 1
Don't csrwe with the side covers...they have more to do with expansion than anything else
