Hello guys, I've got a problem hooking up the controls to the above stated motor. I don't know what model it is, the mounting bracket says "Cabrea EL85/8501-820929". I was told it was a Suzuki trim/tilt. The issue I'm having souldn't be that difficult with your help. I have a manual for this motor but it doesn't say what color wires are (i.e. magneto, choke, if it does, I can't find it).
Here goes,
yellow w/ white stripe?
two solid purple together?
purple w/white stripe?
black.....ground
red w/black stripe.....hot/12v pos.
double yellow w/black stripe?
The reason I need to know is the ignition switch I have has these letters,
m, b, m, c, s, i........not a. I tried switching a and i and it didn't work. The problem I'm having is that the motor turns over but I'm getting no spark. I know the motor has spark because I saw it run yesterday when I bought it. Any help is much appreciated and if you need more info let me know!
Here goes,
black.....ground
