Hi all - i'm sure most of you have seen my posts...
Basically quick lowdown...
I got a new to me merc 50 '81 outboard that ran but needed the gearbox oil and impeller doing...but the problem was the box wouldn't come off...
Anyway so got the box off, new impeller, pump housing and oil...
So i then got it together at the weekend, started it 3rd pull, not bad for not running for 9 months... i then left it running for 5 mins no problem... it was on muffs so not too high revs...
Ok so come today, we dropped the boat in the water, it was a 10 mile driver from where the boat was... got the boat in the water went to pull start it, must have tried 30 times, no joy, in the end had to use a little easy start and still another 10 pulls until it fired... i then had to do another 5 pulls before running...
So my question? why was it that hard to start? when running it ran fairly well? any ideas?
also when idling at tick over it seems to stall after about 30 seconds - bump up the rpm 500 and it seemed fine... ideas?
flat out with a 14p prop on i was hitting 28mph on a Glastron ssv151 is this about right?
finally when i was flat out about once a minute i could here a ting kind of light metal on metal sound from the outboard... any ideas?
thanks in advance...
