81 rude gearcase problem
rcb130
I am helping a friend repair a 1981 rude v6. I am stumped by the following problem. When I first disassembled the lower unit to replace water pump and do a reseal on the gearcase I notice the driveshaft would only do a quarter turn. Once the pump was off, it rotated freely. I put the new pump kit on, resealed the top end of the gearcase and pulled the bearing housing out of the bottom due to a bad bearing. I replaced the bearing and put new seals in the bearing housing. After reinstalling the bearing housing, I find the driveshaft bound up again. Only a quarter turn in any gear. Remove the bearing housing and all works as it should. I have adjusted the shift rod to the the repair manual specs. Does anyone know or have an idea what is wrong with this gearcase? Also, it is not the original gearcase. Is there a way to identify what year the gearcase is? Thanks in advance for the help.<br />Rob
