Rebuilt the power head fuel pump new fuel lines rebuilt carbs. Im having problems at ifle i can choke it get it to crank and it will idle for about 30 secs to a min befor it starts to bog and shut off. At this point if i tap the choke it will prime the carbs and idle back up and do the same thing. This only happens when i have the boat in the water and backpressure on the exhaust. With the muffs it runs fine . When i remove the airbox. It is very wet with fuel mixture. I have 2 ideas. An air leak in my fuel line Or my carb floats set to low? Has any one had this problem Or any idea where to start? I have a clear fuel filter in line right befor the motor and it stays full with fuel. The entire time? Help!!
