'82 Mariner 90 HP Carb set up questions
jamescody
The manual is a bit vague regarding setting the idle speed on the Mariner mill. It talks about loosening locknut on cable barrel and adjusting it that way. I'm not quite sure?? Is it taling about the hold-down where the accelerator/shift cables come into the motor housing? The motor runs great bun stalls a fair amount when It is put into gear. The idle is about 100 rpm lower than it is supposed to be....can anyone kindof give me a condensed version on how to set up the idle speed??<br />Thanks
