I have 200 v6 that is driving me nuts it's a 2.0 liter. When I bought the motor it had been in a small electrical fire I replaced all wiring stator trigger power packs etc. the motor cranks easy and runs great ,but if run it hard for several minutes it runs hot. The motor is on a heavy 20ft center console with t-top . I run a 15 prop it only turns up about 5000 if the tach is accurate about 35mph gps. I have a new water pump and housing, took the manifold apart to see if it had a blockage pulled heads everything looked great good compression on all cylinders the timing is right what could be the problem? I don't need a rocket just something I can run about 20 mph for more than ten minutes. Would smaller carb jets help? or am I overlooking something. It always has a good water stream from tell tale I can run for days at low rpms with no problem .
