I have been dealing with a bogging issue on my 82 wellcraft that has a mercuiser 140 engine. The boat has a new fuel pump and lines as well as a revbuilt carb, and full tune-up.
The boat ran great for about half an hour and then started bogging in the middle of a run and has been bogging down every since when in drive.
I recently readjusted the timing on the water because of some pinging that was happening and that went away but it still bogs at WOT.
I took it out again last night to rule out the fuel because the boat sat for 5 yrs although I have put tank cleaner and fresh fuel in. I ran on a temp tank with new 89 octane gas and had the same "BOG" issue, the difference this time out is that i accidentally slammed the drive in reverse and the RPMs climbed and the boat ran faster backwards without bogging down. Does this seem like a prop or some type of gearing issue. Just wondering now if I have been checking the wrong things.
The boat always starts and idles perferct and never dies out on the water, just this bogging issue when in drive and can never get above 200-2500 rpms.
Looking for some help.
