'82 mercury 50Hp stalling when in gear.
rotorhead
My 1982 50hp always stalls when I put it in gear. If I don't get on the throttle right away, it will stall. Is there an adjustment for the idle when its in gear?
12Footer
Re: '82 mercury 50Hp stalling when in gear.
Welcome to iboats. First thing, stop running this motor until the problem is fixed. The reason being, it is probably missing on one or more cylinder. If the miss is caused by fuel starvation, you could be grinding those cylinders not receiving fuel into metal shavings (no gas/no lube).<br />Buy or make a sprak tester, and test for spark.<br />If all four have sprak, check plugs for two dry ones ,side-by-side.. While you have the plugs out, note thier condition (fouled? too clean? metal particles on anoode? ect).
