83 115 johnson RPM'S
dk990496
What is the recomended rpm speed for this motor right now at idel it runs at 10,000 rpms with out load is this high or not.
crazy charlie
Re: 83 115 johnson RPM'S
I assume you mean 1000 rpms at idle.4500-5500 is the wide open throttle range. Charlie
dk990496
thanks Charlie yes 1000 it is running 5500 - 5600 wide open but did not no if 1000 was to high at idel.
Solittle
1,000 rpm is a bit high. You want around 6-700 rpm in gear. Back off a bit & give it a try.
OBJ
dk...is that 1000rpms in the water or out?
dk990496
OBJ this is out of the water maybe in the water the RPM'S will go down or should i back it down out of the water
Dhadley
Set the idle in the water and in gear. The backpressure of water in the exhaust housing will bring the idle down somewhat.<br /><br />Good luck!
