Past Friday, on the way home with a full boat, lost power at almost full throttle. Engine would start up, idle fine, but has little power at WOT. You can hear the engine rpm increase and the boat try to increase power but would only run at slightly higher than idle speeds even at WOT. Had a similar issue lately and adjusting the idle screws on the carbs seemed to fix it. Took it out Saturday alone and spent over an hour adjusting those screws every which way. It seemed to help slightly but then two accelerations later it would be back to its issues. If I could get it onto plane I was usually good. Thought I had it fixed but the next day with a loaded boat no such luck. Idled out, anchored up, everyone else enjoyed the day while I could stop being bothered by my issues, then idled back in.
I plan to rebuild the fuel pump just in case (and its cheap and easy) to see if that helps. I am reluctantly thinking about tearing into the carbs as well. Also, I just remembered that I have had tape over the fuel vent for a year now that I put on to prevent water from splashing into it when beached. Had that issue last year. I would think that that is not helping my issues and probably creating unneeded load on the fuel pump, but have an fine like this for awhile (not completely cutting off vent).
Also, I recently had to repair and swap the carb linkages. Do these carbs need to be sync'd when this is done? Is this difficult to do? I believe I have a Merc manual somewhere but cannot find it for the life of me. May have to buy another to get the details of syncing.
Thanks
Thanks
