83' 140 evinrude wont go into gear now after I put it into gear at higher RPM
aviator79
So I went to leave the island Sat night and my moter would not go into gear. Today I recalled that I did have the idle adjust up when I put it into gear earlier that day. It did clunk into gear as it was reved up to 1000 to 1200 I would say. I didnt think much of it more than "woops im an idiot and dont do that again." So it ends up being a horrible night.
I tried it again the next day and still nothing. The linkage seems to move far enough, but there is clearly strain on it as it slightly cocks at the connection to the shift lever in the engine (maybe I need a picture).
Anyways did search on here and didnt come up with anything. Its clearly not a spun prop as I just bought it. I have a manual, but not sure what I need to do to figure out how to repair it. It doesnt grind or anything. Im starting to think the motor is cursed as every time I go out something breaks.
Thanks.
noelm
Re: 83' 140 evinrude wont go into gear now after I put it into gear at higher RPM
is the Engine running or is someone turning the prop when you are trying to shift?
aviator79
It is running.
aviator79
Any ideas? I guess disconnecting shift cable and seeing if I can get it to go into gear...
the manual says to take gearcase apart I need to be able to put it in reverse. Im just a complete noob to this so...any help appreciated.
