Sailormannj
- Sep 4, 2002
- 36
I suspect that the elbow fitting on the side of the engine that has the water output may be clogged. Motor has a new impeller, I cranked her up the first time this year got a steady stream of water then some dribbles. Is there any easy way to get this elbow off to clean uit out without removing the power head? Can I take the entire plate off that it is on and get to water passages?<br /><br />Thanks
