i recently bought a 25hp 1983 johnson electric start outboard that was missing a powerpack. I got the powerpack and tried to test run it in a bucket today and it did not start for awhile it wold pop out the exhaust, is this called sneezing? water would splash violently out of the bucket. i did get it started without using the choke and it ran good for about 10 minutes then died when i was messing with the throttle. i tried to start it again but could not and gave up after another ten minutes. i know i have fuel and a good strong spark but i dont know if it is at the right time it would sort of run when i was cranking but if i let off the button it would usually ?sneeze? then stop. also How violent should the water be in the bucket when it is idling? it is currently making big splashes making a good amount of water exit the bucket just from the exhaust. what does the black thumb srew on the front of the carburetor do?
thanks
Forrest
thanks
Forrest
