Hello again, it's the newb. I put the key in the ignition and nothing happens when I try to start the motor. So I got to looking at the starter solenoid, comparing it to the pic in my seloc and it appears to be wired completely backwards. The way it's wired right now, starting from the upper most contact, is as follows:
Top contact----to the starter
Next one down---to ground
Next one down---yellow w/red stripe
Bottom contact--to battery
The seloc shows it completely opposite. When I take my ohm meter and read the yellow w/red striped wire to the solenoid housing, I get continuity. Does that sound right? It would seem to me the ground should read to the housing seeing as it's wired to the cut out switch. Can somebody verify the set up on their motor or send me a better reference then the Seloc??? By the way, the picture I am going from is on page 6-19. Thanks. Chad
