motor will start and rough idle w/full throttle and emits heavy gray/white smoke from exhaust. Dies at any other throttle setting lower. Engine does run better when I adjust the screws in, located at the top, above the carb throat(idle mixture screws maybe?) But it still won't idle low enough to engage in gear. The last time we had the boat out a couple of years ago is when it started. Ran great for a few hours, then the motor started running slower and slower. so we headed back to the ramp. by the time we got to the ramp it was barely running and died at the ramp. It seems to be running way to rich. Help!!!
