Riverrat8428
- Feb 4, 2008
- 37
Replaced a complete water pump assembly on my cross flow. The new pump from OMC appeared somewhat differant than the old pump. I also replaced the thermostats and the check valves and springs. I took the motor on a fishing trip and it really pumped well maybe too well. I trolled a lot and the mid section of the lower unit where the two square hole are had lots of water coming out and got really black. I have since changed the thermostates again and the check valves and it seem about the same. I have a infa red temperature tool and this morning at the dock while idling in neutral I saw the temperatures on the top of the block just before the head to be about 98 degrees and the cylinder head to be about 114. Could the new pump be the problem may have more volume then the old style.. What should I do.
