Hi! all,
Bought 83 merc 25 hp that had been sitting for over a year. Took off carb and cleaned. Reinstalled and used new gas. Starts right up using key choke and runs for just a few sec. Won't start using manual choke.Wondering if maybe fuel bowl float is not set correct? Also throttlle shutter(butterfly) is closed at start.Is that correct?? Seems like it should be. Tried adjustng the idle screw from stop out 1/2 turn each time.No luck.There is plenty of gas going to carb. I am new at this so any help would be very much appreciated. thanks much. John
