My 83 suzuki would rev up and loss power and speed.This happened off and on for months.
We finally took the boat and motor in for service and was told the prop had spun. It has a ruber insert. We got a new prop and it has worked fine.
We now have about 75 hrs on the new prop and the problem seems to have started again.
It strted to rev up and loose power.
My question is this.......... can there be another cause of this problem?
If it indeed is spinning again..what is spinning? Is it the motor shaft on the splined inner rubber?
Or is it the the outer rubber spinning on the inside of the prop housing?
