I have a 60hp 1983 Suzuki DT60 Engine. The water pump of the engine wasn't working and it overheated and turned off. Now the cylinder pressures are 72 and 94 psi. Engine doesn't start. The fuel pump will not pump fuel. However the engine won't start even if the fuel is pumped manually. Are the cylinder pressures too low or what might be the reason for the engine not to start? Does the fuel pump take it's pressure from the cylinders or how is the pressure made for the pump?
Please help if you can.
