84 90hp vro pulses and dies
draino
Help. Let me say that I've just about given up. Last season I replaced the entire vro system complete with the tank and new pump, and horn. thinking that this boat would run more than a couple of times around the lake and shut down. I have a built in tank which has a new hoses and buld and vent and primer bulb and in line fuel filter. I have had the the carbs cleaned and rebuilt. This motor will flat fly if you can get it into detent without it dying. while setting the idle under load it seems to pulse and then die. Could I have a bad power pack on one side. I think that I hear a slight misfire or miss at fast idle, but at speed or 1/2 throttle I don't experience any of that.
