Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
i need to know if there is a good cleaner to spray into the carbs on my engine that will remove help it run smoother ? or do i need to have them professionally taken off and cleaned? thanks jim
Hi james e - Welcome to iboats.<br /><br /> regarding your post you should re-post your question in the Johnson & Evinrude Outboard Troubles/Repair forum.<br /><br />you'll be better served and it'll get a heck of a lot more attention than here ... <br /><br />good luck
