Re: '84 John 75hp 2 wire trim motor question
Don't worry about the trim rods not moving. The manual release allows the motor to move, but not within the trim range (1st 15 degrees). Take the motor off of the assembly and try to direct power it again to make sure that the problem is not a binding pump. If it still will not spin, then you can either replace the motor, or attempt to repair it.
I recently rehabbed my trim motor, and it works great now. When I removed the screws on mine, about a cup of water came pouring out. I had to resolder a wire to the brushes, but the brushes still had plenty life left, so I just left them in. A good cleaning of the armature and stator magnets was needed (use emory cloth). If you need to replace your brushes, find a starter shop in your area. I see that you're in Frisco. If you can't find a shop there, check out D.C. Starter Services in Denton. When I rebuilt my starter motor, got a set of brushes there for $12.
I'm including a few pics of the project. If you decide to fix your motor, let me know if you run into any problems.
