wcsd106
- Mar 27, 2010
- 182
Recently I had been having troubles with my 1984 Mercury 200HP V6 Outboard not going over 3400RPM. In the course of testing the stator, I found that the blue circuit had a break in it.
I ordered a new CDI Stator from Iboats. The salesman I spoke with said that I needed this stator after doing some cross referencing with CDI.
The stator arrived Thursday evening and I got it installed that night. I didn't have time to test, so I decided to give it a test today before going to the lake.
I have found that I am no longer getting spark to any cylinder. Since the stator is the only thing of the ignition system I have changed, I am assuming my problem lies there.
I tried to match the stator up the best I could to the position of the original stator. When I found I had no spark, I moved the stator one hole clockwise from original position. I still had no spark. I then moved the stator one hole counterclockwise from original position and still had no spark.
Not having a DVA meter is putting me at a distinct disadvantage, I know, but I have tested all leads with an Ohm meter and am getting the correct values per the CDI troubleshooting guide.
I have attached a photo of my original stator to help verify that I was sent the correct replacement stator as linked above.
If anyone has any ideas on why I am no longer getting spark I'm all ears.
Thank You.
Thank You.
