Removed upper and done the pressure test again, and it holds 12 psi for ever, yet when I top it up and run it on the muffs i see oil film on water output and no oil shows on the stick. Is it possible that the upper builds up pressure and forces excess gear oil out the bottom oil seal until it reaches a happy pressure where the gear oil wont push out? I fill it up to the stick mark and maybe a little more for good measure. Its say 16.6 ounces is this correct? When I drained it to do the pressure test I got about a coffee cup of oil, after 10 min. of muff run.
Definately need input her guys. Want to go boating this weekend.
