'84 Wellcraft American 180
wkeithk
Hello everyone - My name is Keith, I'm West of Chicago. Just picked up the above. Have receipts for new lower end, starter, complete tune-up. Mercruiser 140. I knew it needed a floor. I've got the floor out, the stringers appear to be solid when tapped with hammer. I have not cut out any styrofoam, it is dry, should I? Just as precaution? I do need to check the transom. Can I get some advice or suggestions as to what else to look for. While I have it open, I am going to replace fuel fill tube, vent tube and fuel line. I'll post some pics as soon as I get them resized. Thanks in advance!!!!!
Woodonglass
Welcome to iBoats!
Drill core samples in the foam, stringers, motor mounts and transom. Tapping with hammer tells you nothing. 1/4" drill for sampling stringers, Motor Mounts and Transom. Drill about 1" deep.
Use a 2" PVC pipe with teeth cut into one end and hole drilled thru the other end to insert a screw driver to assist with twisting. Top of foam can look dry and be water sitting between the hull and the foam.
Looking forward to seeing the pics!!
wkeithk
Starting removal of carpet and floor
Woodonglass
I'd remove a small section of foam to see if there's water under it. Then drill core samples low down on the stringers Motor Mounts and ttansom.
