My Yamaha 70hp outboard hesitate when I try and go to WOT from idle about 50% of the time. If I back off the throttle and bring it up slowly or wait about 5-7 seconds it will then run fine. It actually runs very good at WOT after the hesitation but if I stop the boat and immediately try to go again it will repeat the same hesitation. The other 50% of the time it takes off with no hesitation. I read a number of posts and I think it is either a fuel pump or timming problem. I rebuilt the carbs last year and this problem didn't start until the third or fourth time I had it out this year. I was planning on rebuilding the fuel pump but wanted to get some feedback first. The compression is about the same on all three Cyl. It is a little low but I expect that with an older motor. Any help would be appreciated.
