Auxlarry
- May 21, 2010
- 304
Hello All,
It appears that I have a water leak somewhere in my mid section from the water pump. My pump is new but I still only get about 3 psi when running. I removed the LU and hooked a water hose up to the supply tube to the engine and my pressure gauge went to 10 but there was a lot of water coming out around the supply tube at the top of the midsection.
My book is not clear as to how to remove the exhaust adaptor (piece between the powerhead and midsection). how do I remove this piece once the powerhead has been removed?
Thanks,
Larry
Thanks,
Larry
