therosses5
- May 31, 2011
- 18
I'm 57 and not a mechanic. I can only go 5mph max in a 14' Smoker craft. While in idle, I can pull the spark plug wire from the bottom and it runs the same. My bottom cylinder is not firing. I swapped the sp wires by only disconnecting them from the spark plugs, then swapping. I was hoping the bottom would fire, but the best result I could get was like a spit of an ignition.
I want to swap the wires outright, but it looks like the wires are hard wired to the ignition coils, so I'm apprehensive about pulling too hard. There is NO boot on the coil end.
I've read Leroy's Ramblings multiple times, searched the internet, and watched numerous videos.
Does anyone know if I can pull them off without ruining a "possibly" good coil?
FWIW the motor runs great on 1 cylinder aside from little power. It trolls great! I can start it cold in 2-3 pulls.
