CaptainD101
- Jun 15, 2010
- 91
my motor is about '85-'87 evinrude 90 hp that is running strong on a 16' astroglass. Well I finished finished fishing the other day and tilted the motor all the way up and drove it home without the stern saver. I was hitching up the boat and went to lower the tilt to put the stern saver and it wouldnt go down. The hydraulic motor is running when i push down but not retracting and when i push up it the hydrualic motor is running and making a maxed out sound.
Did i overlift the hydraulic and get it stuck? Well first i tried to add more fluid to see if it would build preasure, and nothing happened. Then i pulled the top line going to the cylinder and learned this one pushed the fluid in. Then i pulled the bottom hose and pushed down on the motor and all the fluid came gushing out. Now my motor was almost down but I couldnt figure out how to lower the smaller hydraulics which trimms the motor. This got me on the water but at just idle speed because the boat wouldnt plain out.
full view
I added fluid here
Removed this top line going to cylinder, pushed fluid in
Removed this line from under and pushed motor and cylinder retracted
Also removed this plug but not sure what this one is for
full view
I added fluid here
