New member and new to working on outboards so any help would be appreciated. I have what I believe is an 85 force 50 hp with an 88 head on it. I got it with a boat that I am going to restore and would like to use the motor for now. I couldn't get it to start with fresh gas or starting fluid. Problem is I don't have spark to either plug. I tested spark with a tester that replaces the plugs to find no spark on either wire from the coils. I plan on ordering a repair manual but was looking for a starting point in the meantime. I've read a ton of threads and seen a wealth of information but alot of it is like reading a foreign language. There is a crack on one coil which I will try to seal up. Also a red wire that goes up under the flywheel that is frayed but doesn't appear to be grounding out which I'd like to replace. Can I pull the flywheel without potentially putting it out of time or should that be a concern? Anything to inspect while it's off? Put 2 new BR6HS plugs in it until I get the B6HS plugs. I am posting a few pictures to show what I'm working with. I know it's a long post but wanted to paint a clear picture of what my limited experience has noticed. Thanks in advance for any help I might get.
