Re: 85 90 hp evinrude power problem
I meant to go to an auto parts store and purchase a spark gap tester, you should get a strong spark with a 7/16 gap on each coil. After you have eliminated fuel and compression you are pretty much left with ignition. CDI electronics has a great troubleshooting guide in the support section of their website. you will need an DVA adapter and a multi meter, to preform test outlined. could be spark failing under a load as EMD mentioned. but a spark gap tester is cheap and great way to find weak/bad coils.
