85 Evinrude, worth looking at?
Bob_VT
Re: 85 Evinrude, worth looking at?
Well the 1985 is a true 85 hp at the prop.
You need cables, controls, electric cables......prop.... and $500 is his asking price ;)
Ask about impellar...... pull all four plugs and use a rope for the pull start and you should be able to get a compression reading that is close.......
Not all 85's had tilt and trim .....check for it....
Ebay usually has controls with electric cables.
5150abf
Mid 80 Evinrude/Johnsons are some of the best motors out there if they were takin care of, they still made them right back then with a minimum of plastic parts.
Concur onj the cotrol box, they are on Ebay all the time.
ezmobee
Didn't think they made an 85 in 1985. I think that motor is a good deal older than he says it is. I think they became 90s somewhere around 1979 or 1980.
I just looked up the model number. It's a 1974!!!
I'd want controls with it for $500. Still a good motor.
ozenine
Thanks guys. Something inside tells that this can be the "surprise" motor..... It could hav been submerged, blown, etc, etc. I will wait for the one taht comes of the floating boat, not the one that was basterdized. Not worth the trouble looking for controls either.
ezmobee
Well it does use the standard OMC controls. Easy to find. Use the 1974 information and offer $300. If it has good compression, everything else is fixable. I had a '73 and could still get most parts for it. I think if I had needed a lower unit it could have been pricier than newer models.
OMC made a number of design changes around the 1978 model year that carried through for many many years into the 90's. A '78 or newer motor would be idea although I wouldn't avoid a '73-'77. '72 and older are electric shift. That I would avoid.
ozenine
Thanks buddy! I will try 300 if not then it is not really worth it
jay_merrill
I have the same motor and it is, indeed, a 1974. The model number tells the story, but all you have to do to confirm it as an early70s motor, is to look at the powerpack (2nd photo, 2nd row) - its one of the original, aluminum cased units, used during that era. Frankly, I surprised that it still works .... if it does.
I wouldn't pay $500 for it, but the motor might be worth a look, if you know what to look for. My general view of these motors, is that they take a minimum of about $600 to get them in completely reliable shape. In order to do that, you have to start with a motor that is mechanically sound. From there, its usually a matter of rebulding the carbs, ignition system, new fuel pump, water pump, sometimes rectifier, etc.
"Buyer Beware," definately applies.
