Jeremy Brunder
- Aug 17, 2011
- 7
Now that i have the new magneto in the boat i can go back to the old problem it has, the choke does not always click, i have a new solinoid in it and have changed ignition switch, when it does not work it shakes a little bit but does not close them, it has 12 volts to the solinoid when it does not work, when the i replaced the solinoid it worked for a week then same thing, i adjusted it and it worked in the yard , well then the magneto went out and that was the least of my problems. it has been working on and off for about 3 years, i never looked into because if i had someone with me we would choke it manualy with the cover off engine, but now i would like to fix it right and be done with this problem.
