My 1979 85HP Chrysler outboard on my Bassrunner has been running great for years. Last week about 3 minutes after getting up on plane at WOT at the normal 5500 RPM the engine started losing power. It will now not idle without giving it gas (RPM's at about 1,500) and when running on water and it wont get over 2500-3000 RPM
I changed the plugs, new gas lines, primer bulb, fuel filter, fuel/water separator but nothing improved at all. I am getting a spark to all cylinders and the primer bulb gets firm just fine. I'm not sure about compression, and I don't have equipment to test it.
I'm a bit of a novice, can someone please let me know the best next steps in order for troubleshooting this issue?
Thank you!
Thank you!
