85 hp chrysler
blademro
have just cleaned the carborators and cheeked the ignition had it out and the water and u could not put it in gear with out it dieing tried adjusting the carbrators but the onley carb that made any adjustment was the number 1 carb i have spark and fuel in all cylinders cheeked the fuel recirculating reeds and the screans were cloged can that cause my problem and open to other advice
jerryjerry05
Re: 85 hp chrysler
Start with checking the compression and spark.The recirc system won't make that much difference in the way it runs.That's just for using unburned fuel.
Check the fuel pump for a bad diaphram.
Then the idle in gear/warm should be about 750-800 rpm.
1st post in the Force section is a linc and sinc by FrankA.Do as he suggests.Then reset the air screws.All the way in and out 1 and 1/16th turn out. Then motor running,warm and in gear.Turn the air screw in till it makes the motor buck.cough.stutter or stall.Then out 1/2 turn.
Do this twice.Then reset the idle.J
blademro
Re: 85 hp chrysler
i have got 150 of compresion on each cylinder and strong spark on all 3 cyinders i have followed those instructions and my number one cylinder seems to adjust just fine but 2 and 3 do nothing its like they r not working and i tried with my old carbs and then got another set of carb s for that motor and same thing agian
snwwlkr
Re: 85 hp chrysler
If you have 150 psi on all 3, spark on all 3, you've checked the reeds... its got to be a carb/fuel issue I would think. Double check the floats maybe? You could even swap the carbs around. Timing is worth a good look also, must have/borrow a timing light. Read about "static timing" to driveway tune. Does it start up easily?
jerryjerry05
Re: 85 hp chrysler
#2 runs the fuel pump.You check that?
Have the carbs been cleaned latley?Maybe the floats need adjusting.The needles are clogged.
Check for water in the gas?
All three plugs burning right?
