85 hp force motor eating 6 gallons of fuel in an hour, and 22mph top speed?
bradyz25
its pushing a 16ft sea nymph some one took apart the throttle control and messed around in there but idk if thats whats causing it to eat gas or only go 22 mph. i was told she should at least be in the 34 mph range. boat aint that big.
Ibl0wstuffup
Does it ride low in the water? Maybe there's water trapped in the boat. Does it run smooth?
jerryjerry05
Welcome.
First do a compression test.
Spark test.
Then check the fuel pump diaphragm.
A 16ft with an 85 should do 35-40.
If the foam under the deck was saturated it would have to have 2000# of water to make it that slow.
Top post in the Force Forum is a couple of self help posts.
Look up the link and sinc one and check it out.
Check the fuel system for old and damaged hoses.
Post the results.
achris
More fish than mountain goat
The 'divide by ten' rule of thumb for fuel consumption of a 2 stroke at full noise has this engine sitting in about the right place. 85hp/10 = 8.5 gallons per hour at WOT. You used 6 gallons in an hour. Sounds about right. As for the vessel speed, that's not right, the guys above should have you on track for that.
Chris......
HotTommy
I have nothing specific to add, but here is some food for thought. If it is using less fuel per hour than average at WOT ( 6 vs. 8.5) and it is running slower than expected, perhaps there is a connection. You may not be getting full WOT and that could be related to the work on that throttle control that you mentioned.
Jiggz
The best reference to use if a motor is actually running at its optimum is the RPM and speed over water or GPS speed. An 85 HP Force is rated between 4500~5500 RPM at WOT. How fast it will run a boat on those rpm's depends on size, load, trim and sea conditions. But normally that speed should be around 35~40 MPH. So the first question is what your WOT RPM?
bradyz25
have one more question guys. my transom from top to bottom of v is 22 inches, if I get a motor do I get a long shaft or extra long shaft? I dont buy the wrong thing
achris
Extra long, and raise it up on the mounting bolts the extra couple of inches.
Chris.....
