I have a 1989 85 hp force outboard with the 2 piece driveshaft. I can't find the serial number but the diagram ref. a 1989 85 hp ser. #ho858x89g seems to be accurate enough.
The problem I am having is I removed ,F498891 | PIN-SHIFT PIVOT, by accident and wound up rebuilding the lower unit. I didn't see how the shift coupling assembly came off and I keep having a problem when its reassembled. The shift coupling has 2 short forks and 2 long forks that should be attached to the lower shift linkage rod with the forks pointing down and to the rear. The diagrams all seem to indicate the short fork goes to the rear of the housing,which is the only way it seems to want to install correctly. Well when its all put back together if you pull up on the shift rod you hear a clunk and the shift yoke drops into the gear housing and apart it comes again. Yes I reinstalled the pivot pin. When disassembled if I try to rotate the coupling assembly 180 degrees the shift linkage rod won't line up to be connected. When the linkage is assembled with the fork pointing down it reverses the shifter. In the forward position the clutch goes onto the reverse gear and in the reverse position the clutch moves onto the forward gear. The Big question is does it sound like I'm installing something ,the fork, incorrectly. I purchased this engine on the boat recently and I've only run a few short times.If anyone can help it would be appreciateed, Jeff
