Protector44
- Apr 9, 2018
- 4
Hi there! I'm new to the forum and hoping one of you can help me. Thanks in advance for taking the time to reply. So i have a 89 85hp force that i'm putting on my 69 lund. I know it's not the best motor but it was free and it runs good. When i got it it was on a 89 bayliner capri. The motor was up when i got it and after I found the bad wiring and bypassed the kill switch I got power to the trim. It went down but not up. I took the motor and wiring harness off so i could work on it inside. I hooked everything back up the way it came off except i ran a lead from the fuse block to my toggle and same issue so i went and got 2 new relays and put them on and as soon as i toggle either way i blow a fuse. So this is what I've figured out so far with my new relay on the port side and the old one on starboard side green wire trims up and blue wire blows the fuse so i switched the leads and blue trims up while green blows the fuse. Then I switched the relays so my new one is starboard side and the old one is port side with leads hooked up correctly and the blue wire trims down and green blows the fuse, switch the leads and green trims down while blue blows the fuse both new relays and i blow a fuse either way i toggle. What am i missing? Help please!
