85 hp us marine won't stay running
So my 85 HP us marine motor won't stay running. Cleaned everything, fresh fuel and oil, battery charged. It fires but doesn't idle very long and dies. I have done about all I can. Any suggestions before I take it to a Mechanic
Sounds,to me like you are having the same issue i had w my 65hp chrysler outboard i found two problems to be the cause one was that my fuel lines from my tank to my bulb were housing dead bugs from sitting this caused the motor to starve for tuel another was that my floats and fuel mixture screws were improperly adjusted after fixing all of these i seemed to no longer have this problem .i have found that to save yourself a great deal of headache its easier just to go ahead and buy all new fuel lines hoses and clamps rather than look for where the kines,are sucking air or clogged and/or leaking .hope this helps thanks .
jerryjerry05
Do what jay suggested(new hoses and squeezie)and then change the diaphragm in the pump.
