84 115johnson newbe
- Jul 22, 2013
- 31
I just tested with soapy water and a radiator pump, the gear case which would only hold about 4lbs of pressure before bubbles started coming from the area on the outside of the 4 bolts in the prop housing. Looking inside from the rear the prop seal itself looks good. Its like the bearing carrier is leaking down in the bottom and not where the bolts attach.. "Do I have a major problem?" Just bought the set up and haven't had it in the water other than running the engine.. A seal or crack?
