Hi,
Model# j140tlcos.
Im wondering if someone can explain the controls i have attached in the picture. Obviously the big arm lever is for forward and reverse. But what is the starting procedure? It looks like the lever on the top side of the box may be the choke?
As for testing it with the muffs on in the driveway. I hooked up the muffs, i cant seem to get them to seal 100% on the sides of the lower. And does the telltale only work when the engine is running? I didnt get any water from the telltale during cranking(comp test) nor just sitting still.
Finally, the boat has a built in gas tank. Its a 1985 Doral 164. 16.5 ft long. Tank specs are worn off the top of the tank. Does anyone have any guesses what its capacity is? The guage says its about 1/4 full. And its all bad gas. So im just trying trying to figure out what to do with all that gas and how many gas cans i need in order to remove it from the boat.
Model# j140tlcos.
