Re: 85 Johnson 25 Hp Compression
You are fine with those readings. The key is that each cylinder does not differ by more than 10%. Different gauges always read differently and it depends a lot on the quality of the gauge. I use a Harbor Freight compression gauge which I am sure is not that high quality. It does the job though for the few times I use it.
